is there a setting can use when exporting a svg file of my circuit. it looks good on in fritzing. but when i export , the center of my copper pads are open. I want the entire circle to be solid, not open( see picture). thanks
AFAIK, no. The hole in the middle is intended to give the drill a starting point so it is centered. If you don’t want the center hole your best bet is likely to export the image as an svg then use either a svg editor such as Inkscape or a text editor to change the pad circles to no stroke and and increase the radius by 1/2 stroke width (to leave the pad the same size.) You can do that as a global replace which will be the easiest I expect (you would need to do each pad individually in Inkscape I think.)
oh ok, i’ll give that a try. thanks for the help
