Female Pin Headers
Hello , How can I get 6 pin, 4 Pin and 7 Pin female headers in fritzing?
In core parts select the generic connector and drag it in to the sketch (by default 2 pin female) then use Inspector (the lower right window) to change the number of pins and other parameters as needed.
note you need to drag the connector in to the sketch before Inspector will modify it.
