FC-51 Infrared Obstacle Avoidance Proximity Sensors Module
Here is a list from my created_parts directory. They should all be in the forums somewhere, but are probably (mostly!) not as good as current standard because many predate the creation of the parts check script. Many of them I don’t remember making, some of them may not be mine and just in the wrong directory :slight_smile: . Then there are a bunch of user submitted parts that I have fixed up over the years that aren’t in this list (and because they aren’t mine, aren’t mine to submit to core either).
1x4 Membrane Matrix Keypad.fzpz
3.2in tft touch screen.fzpz
3.5mm switching Jack.fzpz
5-channel flame detector module.fzpz
6 circuit slip ring.fzpz
12circuit slip ring.fzpz
74LVC8T245.fzpz
74x125.fzpz
74x367.fzpz
74x541.fzpz
18650 battery holder.fzpz
Ceramic Capacitor top view.fzpz
DM860A Stepper Motor Driver.fzpz
DC 3.3v-10v TO ± 12V Mini DC converter.fzpz
DC 3.3v-12v TO ± 15V Mini DC converter.fzpz
DC 5V TO ± 12V Mini DC converter.fzpz
DC 5v-12V input to ± 12V DC-DC converter.fzpz
Electrolytic Capacitor top view.fzpz
fc-51.fzpz
Goouuu Mini-S1 ESP8266 Nodemcu.fzpz
gtm2088argb-21.fzpz
hcmmodu0083.fzpz
sen136b5b.fzpz
HSM-A43 LED Indicator.fzpz
IL612-2e.fzpz
ITG-3200.fzpz
JOYSTICK_10mm_fixed_pcb1.fzpz
Keyes l9110 Fan module.fzpz
kmr1_8_spi_tft.fzpz
KWM-R30881CUAB.fzpz
KY-026.fzpz
ky-038.fzpz
LM386_fixed.fzpz
sheilded_nomag.fzpz
Membrane Matrix Keypad_mine.fzpz
Micro Slide Potentiometer.fzpz
Mini-360 DC-DC Buck converter.fzpz
MOSFET-NCHANNEL_fixed.fzpz
non-restable_thermal_fuse.fzpz
nrf24le1 larger (probably not finished as no fzpz file)
nrf24le1 small "
PH10PIN-2.0MM.fzpz
Pololu QTR-8 Reflectabce Sensor array.fzpz
roborio.fzpz
Rotary_Switch_4x1.fzpz
S-350-60 Power Supply.fzpz
SBX DSUN.fzpz
sct-013.fzpz
Shortened_LED.fzpz
SMA Antenna Connector.fzpz
soic20.fzpz
STEF12 fuse.fzpz
Stereo POT.fzpz
SWITCH-DPDT-latching.fzpz
tlp185.fzpz
TLV431.fzpz
TO-220-2lead.fzpz
TO-220-3lead.fzpz
TO220-4lead.fzpz
top View TO-92.fzpz
tp4056.fzpz
VA250LA40BP.fzpz
Vex Voltage regulator module_improved.fzpz
Wemos ESP-Wroom-02.fzpz
Wemos lolin32.fzpz
xr10910_qfn40.fzpz
