Is there a way to export the PCB design top and bottom layers as two different illustrator (or dwg) files? The ultimate goal is to cricut the mask and etch to make my own PCB.
Thanks,
Dena
Thanks,
Dena
Fritzing has options (on the file menu) to export, for production, etchable pdf and svg files. Illustrator can read at least the svg. I don’t know if that export is ‘per layer’, or would need to be split afterward.
The gerber export generates separate files for top and bottom layers.
