I’m trying to find a fritzing part for a esp8266 with built in oled.
link
I’ve tried google but all I can find are seperate 8266 and oled parts.
Does anyone have a suggestion where to find it?
link
This part should do what you want. Note if you want the mounting holes you need to drag a core parts/pcb/hole in to the sketch, position it over the hole in silkscreen and then set the size appropriately (the mounting holes are not drilled by default.)
ESP8266-nodemcu-0_96OLED_display.fzpz (10.8 KB)
