I modifiyed a part to receive an ESP8266 adapter board. In fritzing it looks like ist should, but when I exported it to svg, it ist diplayed wrong. What is the problem of the part? What can I do to solve it?
Thanks
so edit the breadboard svg in Inkscape and ungroup it (which will typically apply the transforms), then regroup it and rezip the .fzpz file. That appears to have cured the problem as this is breadboard exported as an svg with the above changes:
For reasons unknown the svg is truncated but if you try it with this part file, the svg is correct in Inkscape:
That was from a raw svg file. not parts editor. The truncation appears to have been only a preview artifact as well, the displayed svg is in fact correct, but was truncated on the sides in the preview.
