ESP32 NodeMCU WROOM 30 pol
A breadboard part. A little bit simple with no names for the pin connectors
nodemcu_wroom_esp32
NodeMCU-WROOM-ESP32_30pol.fzpz (222.4 KB)
Thank you fo the parts! :slight_smile:
Perfect! Just what I needed.
Be aware it is breadboard only. There are likely full parts available elsewhere if you need schematic and pcb. A google search of the form “fritzing part NodeMCU-WROOM-ESP32_30pos” should turn up the parts otherwise available.
