Can any one please share part ESP 32 WIFI AND BLUETOOTH
You would need to provide a link to a web site of the ESP 32 WIFI AND BLUETOOTH board you want so we can see if there is a part available. There appear to be several different models that come up in a google search for ESP 32 WIFI AND BLUETOOTH.
This one is as close as there is. It has mounting holes that yours doesn’t but the pins appear to be the same so it should be electrically identical.
which looks like this in breadboard:
yours doesn’t have the mounting holes and may be a bit shorter but as noted should be electrically identical. You want to download the ESP32-38PinWide-fixed.fzpz file.
