In all cases they are missing breadboard layerIds (and usually schematic layerIds and have pcb issues none of which I fixed.) These parts can be used to replace the current ones either by doing “delete minus” which will remove the part but not the wires, replacing the parts with the ones below (you will need to delete the current parts from the parts bin they are in either mine or the adafuit repository) then shutdown Ftitizing to really delete then then restart and load the new parts. If you used delete minus you then need to move the end of the wire on to the appropriate connector to make the connections (it is often easier to just start the sketch again though.)
All these parts now correctly export as svg. I don’t know anything about png export, although there was a late post suggesting to use 1.0.4 for better results due to fixes.
