Is there anyone who is good at doing parts who can do this?
I could certainly make one, but I’m not sure what use it would be. It isn’t likely to connect to anything in Fritzing and would be fairly complex to make. Can you describe why you want one?
I should have added I would need a dimension from the top of the element to the bottom to get the size correct assuming I do this.
Electrically, that is just 2 resistors. Maybe some inductance.
