EDP 8622 on the Drawing
Hello everyone
I am new here and would like to get an ESP 8622 in a Fritzing drawing to make a circuit board from it later.
The placement itself works but I don’t have the posts in the drawing and then I can’t connect the ESP
I haven’t found anything on the net…
how do I get on here?
thank you
Welcome aboard. I assume you meant ESP8266 (as there is no EDP 8622 that I can find) and there are no obvious parts in core parts. So first thing to do is upload the sketch that you are using (the .fzz file, upload is 7th icon from the left in the reply menu) which would allow us to load the sketch and see what your problem is. If it is a part from the net (which seems likely) it may be broken, and the information in the sketch will allow me to fix it.
