Browsed through this forum to see if I could detect a hint but failed.
My question : how can I edit a jumper? Yes, I know how to move or make it longer/smaller bu I did not figure out how I could change the size of it connections.
Is this possible anyway?
Editing a jumper
Doesn’t look like connection size is modifiable. You could create the same effect as a jumper by dragging in two holes as each end of the jumper (it won’t have the wire though.) The size of the hole and ring are settable in Inspector under advanced settings for the hole part.
Thanks Peter, yes, your suggestion already crossed my mind but I hoped that it was possible by simply changing some parameters as is for instance the case with a resistor.
Will do it as you suggested.
Joe
