ım searc the QMC5883L crude part
And we need enough information to do anything with. The template in this category is here for a reason and you need to fill it in. A web site with the physical dimensions and connection information of what ever a QMC5883L may be would be required to do anything. Also a google search of the form “fritzing part QMC5883L” will tell you if there is an existing part (which if it is a 3 axis Magnetometer it appears there are several) this will find it.
ben ölçüleri bulamadım… Fakat belki sen bulailirisn
@Team_Of_TECH_Leader A Google search of “fritzing part qwc588l” turns up this
Thank you. You saved my day.
Dealing with part duplication in Fritzing can be tedious. One workaround is to recreate the part using a flexible MCU like the PIC16LF1824T-I/SL. It supports I²C communication and is energy efficient—perfect for simulating or replacing sensor behavior in custom part designs without impacting power budgets.
