(duplicate) DC gear motor schematic+pcb
I am reaching out regarding this component: DC gear motor yellow 3-6V.
I’ve searched the forum, but unfortunately, I couldn’t find a working Fritzing part for this DC gear motor (yellow, 3–6V).
I’m specifically looking for the version that includes the schematic and PCB views with the two pins.
Could anyone help me with a link or a custom part file for this component?
Thank you very much in advance!
Best regards,
Sebastian
This is likely as close as there is
it has both schematic and pcb although it doesn’t look like the original it has all the required connectiosn.
Thank you very much! I assume the pins are spaced correctly for PCB mounting.
No. PCB appears to be a 2 position header likely intended to connect the the motor via wires. Motors are typically not pcb board mountable.
