(duplicate) Anemometer library
3 CupAnemometer with 2 pin
1 red
1 black
Name: Intelligent Anemometer
directly connect to A0 or any analog pin and GND of aurdino
Thanks
@Akashali Useless. Please fill up the template (copy and paste the below code in a new post)
Have you done a **Google Search** of the part
>fritzing part [part name]
>e.g. fritzing part l298n driver module
[ ] Yes, not found
[X] No/Unread (we *may* ignore this part request if ticked)
**Name of the part**
Name
**Similar work/own work**
In case there are similar Fritzing parts, or you already started work, please link/upload it here:
Leave this blank if there are none
***High-resolution top view, flat image^***
This picture shows the part from above, so that is easy to see where connectors should go, and which diameter they have.
Photo or vector graphic, no links here, please.
***Datasheet/Website^***
Please, please **add a link** to the PDF of the manufacturer’s datasheet/the website where the part was taken from (**must** have ***connector names^***, and ***part dimensions^***)
**Footprint (optional)**
E.g. SOT23-5, TO-220.
(required fields marked with ^)
Please **DO NOT just give images/descriptions**. If you do not fill in required fields, we might not entertain this part request
A google search of the form “fritzing part 3 Cup Anemometer with 2 pin” turns up a variety of hits. The first one while 3 pin (the third pin being power) should do you. Just use the ground and signal pins.
Have you done a Google Search of the part
Yes, not found
Name: 3 Cup Intelligent Anemometer
No. of Pin=2 (1 Black GND , 1 Red Analog Pin)
(but I found with 3 pin cannot edit)
Picture same as other 3 cup anemometer
I don’t have spec sheet or weblink because supplier did not provide me but I can give similar link
https://shopee.com.my/product/664257299/22736275196
In the link anemometer with some kind of meter as well but I’m using Arduino with that anemometer Thank you
Hi @Akashali the reply above yours
