I’m working on a Flight Sim project and looking for a Fritzing component for a dual encoder with a pushbutton. One use would be for an altitude select knob. The outer encoder would do thousands, and the inner encoder would do hundreds. The push button would make it active.
ALPS EC11EBB24C03 is the part number. Anyone up to the challenge?
This should do what you want. A couple of things to note, the switch pins in breadboard are set to female so they won’t short to the breadboard. That means they aren’t marked so don’t appear in breadboard. You can connect a wire to them by selecting 0.1in below the top left and right pads that do show up. In pcb the slot is implemented as a hole (as Fritzing doesn’t do slots in parts. It would be a good bet to print the pcb output out at 1:1 scale and compare it to a real part before ordering boards.
