Dual 16mm right angle pot?
ALPHA DUAL GANG 16MM RIGHT ANGLE POT
Hello, could someone please help me make a footprint for this dual gang potentiometer please?
thank you in advance !
correct size of silkscreen
edit1:
correct the name of the schematic svg as it conflicts with a single gang schematic and probably causes the issue below.
pot-ALPHA-RV16A01F.fzpz (5.8 KB)
thanks Peter,
but the parts too long.
from shaft center to the farthest pot pin is 16mm.
thank you, I appreciate it.
im sorry to report the part still has an issue. the schematic symbol shows the 2 pots. but the pot hidden in the body is unusable.
Unusable how?
this is pcb of the pot above loaded in to Fritzing. It does not appear to be the pot above (which is likely the ALPHA-RV16AF which indeed does look like that but is single gang not dual.)
