Hi guys, I don’t know if I’m in the right forum, but I have a source code to display RTC in DS1307 but when I compile it, I see an error and it tells me that it cannot know the object RTC_DS1307 and suggest another one: 1307. Can you please give me the right library of this DS1307 like your source code so that I can check if my error appears from this?? Thank you
This is likely not the correct forum for this as it isn’t a question about Fritzing but rather compiling code. You need to ask the question in a forum for code development for the processor you are using (such as the Arduino forums if you are using an Arduino.)
okay i get it now, thanks a lot anyway.
Cheers
