Hi, I am look for this part and unable to find it, could anyone help?
Thanks in Advance! ![]()
This should be the part that you want
Haptic Bzzz.fzpz (17.8 KB)
Note: The part may have some major/minor errors (i don’t know…)
Thank you so much!!
I appreciate it!
No prob!
@vanepp for pcb view I get this in gerbv
Means ok right?
(note that for the main part I moved the “A1” text out of the board
There is a slight ‘jog’ in the middle and following traces. That implies that the connectors are not quite on the (I assume) .1 inch spacing in PCB view.
Indeed as @microMerlin points out the first pad is slightly misaligned for 0.1 spacing, connector0pin is 0.132in in X:
but the other pins are all 0.x31in
which produces a slight offset in the pads.
Haptic Bzzz-fixed.fzpz (18.0 KB)
How about now? Other than PCB View (which I alr corrected), are there anymore problems
Looks fine, complaint about terminalIds in breadboard but they won’t affect anything.
Error 18: File
‘part.drv2605l-linear-actuator-haptic-breakout_ce849f2e006f9661fcc64868488e5a8d_6.fzp.bak’
svg svg.breadboard.drv2605l-linear-actuator-haptic-breakout_fe261664377d5fd48a8ca651db9c722d_2_breadboard.svg.bak
Error 18: File
Connector connector1terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector2terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector3terminal is in the fzp file but not the svg file. (typo?)
Error 18: File
Connector connector4terminal is in the fzp file but not the svg file. (typo?)
Spoke too soon, pcb is still incorrect.
possibly because dimensions are in mm, changing to in is a better bet as it makes the dimensions easier to read (as they should go up in exactly 0.1in increments instead of 2.54mm increments.)
AH! My connector0pin is 0.001 off! Didn’t even realise that! Breadboard also!
Haptic Bzzz-fixed(1).fzpz (18.1 KB)
Edit:
I just realised something when checking the part – My viewbox size for pcb is wrong!
Here is my corrected one
Haptic Bzzz-fixed(2).fzpz (18.2 KB)
Indeed that appears to have corrected it.
Alright! @iwaahm please download the updated part
