I created a breadboard with Gemma and Neopixels. When i clicked on a pin i could pull a wire either from the Gemma pins to Neopixel or in the reverse order.
In a new sketch using the small breadboard, Gemma, and red 5mm led I cannot draw a wire from either direction between the Gemma and the breadboard.
Also tried using the Breadboard wire from the parts menu. It will only move with the arrow keys. I cannot drag it. The drop down let me select bend point but i could not bend it. Cannot be moved from pin on breadboard.
I am on a Surface pro 3.
What is going on? Do i have to lock parts before drawing wires?
