I need a DPDT pcb mount part made.
can someone please help?
This would normally connect via wires, and thus any of the dpdt switches should work unless you want to mount it directly on the pcb.
Hello Peter,
thank you for your reply.
i would like to mount it directly to the pcb.
chip
This should do you. As always print out the pcb footprint at 1:1 scale and check it against a real part before ordering boards.
taiway-100-dp1-t100b1m2qe.fzpz (36.4 KB)
