In general the place to start is with a google search of the form “fritzing part ESP32-WROMM-32E” which should find any existing parts. Otherwise you need to provide the data requested (basically a web site for the board you want which contains physical dimensions and connector information.) Checking core parts for appropriate parts is also a good bet (the search field at the top of parts is useful here.) Pictures are basically useless.
I’m also looking for that part if you ever found it.
Some informations about it if this can help
https://docs.sunfounder.com/projects/esp32-camera-pro-kit/en/latest/component_esp32.html
that looks like the one,
Thanks! ![]()
Thank you so much! ![]()
