Does anyone have a Flir Lepton 3.5 part?
Hey there,
I’m looking for the FLIR Lepton 3.5 Camera Module resp. the breakout board v2.0.
Has anyone by chance already created this part?
Thanks
There doesn’t appear to be a Fritzing part available. There are however several different breakout boards available, so we would need to know which exact board you want a part for to do anything.
I’m looking for this breakout board: FLIR Lepton® Breakout Board v2.0
Note enough information here to make a part. No dimensions of the board, you apparently have to register, which I am not interested enough to do, to get any information. We would need a mechanical drawing of the board showing size of the board, where the connectors are and what the pin names are to make a part and none of that is here.
It looks like this is the bottom of the board (and breadboard is usually the top) with no indication what the pins are.
I found a mechanical drawing in german. I will continue searching for an english version.
https://flir.netx.net/file/asset/23497/original
There two should be enough to make a part, no need for an english version.
edit: and here is a part that should do the job. Note breadboard is a bit unusual in that the view is from the bottom (it is usually from the top.) In this case the sensor is on the bottom so you need to be careful of pin1 on the connector (marked with a square.) As usual the mounting holes in pcb are only in silkscreen. If you want mounting holes drilled on the pcb you need to drag a hole from core parts over the circle in silkscreen and set its size to 2mm.
FLIR-Lepton-3.5.fzpz (7.2 KB)
Thank you very much!
Hello, can this part name be changed to 3.1r and re uploaded? I am using the same breakout board, but I am using a different camera version. If this could be changed to 3.1r that would remove any confusion with my schematic design.
It could be done if it is sufficiently different, but you would need to provide the data on the part you want (which isn’t here.)
The part itself is the same but the name is misleading. I am not familiar with making/editing parts to change the name of the part itself that is displayed in schematic view. As can be seen in the picture the name shown is “Flir Lepton 3.5”. I am only requesting the same part, but with the name changed to “Flir Lepton 3.1”
Not worth the work required to change it and make a new part. You can do it for your self by unzipping the fzpz file then editing the schematic svg with Inkscape to change the text from 3.5 to 3.1 then rezip the part or make a new part with parts editor.
