Does anyone has the file for this ili9341 lcd?
i badly need this for my final output project
Not enough information to do anything useful with. Try a google search of the form “fritizng part fritzing part ili9341 lcd” which turns up a variety of hits one of which may be what you want. If not post a web site with dimension and connection information and I will look at making a part.
Hi! I still couldn’t find that lcd, but here is my reference website, i am trying to find this exact LCD for the display
youtube link:
https://www.youtube.com/watch?v=k6qim96wB4k (0:45)
There isn’t sufficient information here either. I had to use google lens to search for the picture to get a web site that describes the lcd (as the link in the article referenced doesn’t resolve) which led me to this site (which is so unclear as to be useless, as are all the others I found!)
however that tells me you are looking for this part “fritzing part 2.8in tft spi 240x320” which is available here (there are several updated copies in here so probably take the latest one at the very end of the post and compare it to your actual board to make sure it matches:)
There are also a couple of more hits if this one doesn’t work out.
After looking over the info in the links @reinael posted, I think that is the common part that I created in the link @vanepp posted.
Direct link to the latest file
https://forum.fritzing.org/t/2-8-spi-lcd-part-creation-help/7851/10?u=just_randy
I know the part works in fritzing and I have even had PCBs made using that part.
Randy
Maybe you can use this one as reference
He explained what specific pins will be use for Arduino UNO R3
Can you get a 2.4 SPi anywhere?
i just bought one still need 2,4 this the one got Amazon.com
Hopefully this works for have tried out cause im on my phone Fritzing-Library/parts/Adafruit 2.4 Touchscreen TFT Breakout w MicroSD.fzpz at master · adafruit/Fritzing-Library · GitHub
The linked component has a completely different pin assignment.
I still have this part:
I checked it right away with the fzp_checker.py. Here is the adjusted part:
LCD_2.8_Zoll_IL19341.fzpz (11.6 KB)
Regards, Harald!
Yeah it seems to be the only thing that’s even close to the 2.4 I have been looking into designing it as best I can using the actual part it self. Sorry for such late reply if I make anything useful I’ll link it here for you to check out.
