Not this particular one but this one exists:
If you can supply a mechanical drawing of the part (which may be difficult) a part can be made, but not without information about the location of the sensors and what the I/O pins do.
Since I expect there isn’t much more of a mechanical drawing than the dimension drawing on the web site here is a sort of part (the mounting holes are not present because there is no information on where they should be) that should do you.
5-ir-array-sensor.fzpz (14.7 KB)
