Does anyone out there have a Fritzing part for a DisplayModule, DM-TFT114-397 Display? I have looked high and low for this model.
See dimensioned drawing for same below:
There doesn’t appear to be one but it is easy to make.
dm-tft114-397.fzpz (5.0 KB)
as usual the mounting holes are only on silkscreen. If you want them drilled on a pcb you need to drag a hole over the top of the circle in silkscreen and set its diameter to 2mm.
