Good day. Is there a way to edit the DIP switch positions? I would like to add the 8 position dip switch beside my motor drivers to show the actual positions I use.
Thank you, cheers.
I think the only way to do that would be to create 2 copies of a 1 position dip switch. One in the off position, the other in the on position. Then 8 side by side switches would do what you want. If the breadboard graphics are done correctly, that would still look like an 8 position dip. Do the single position switches without any on/off label, and use the breadboard text part to show that.
An alternative is to use an svg editor to edit the breadboard svg to change the switches to the pattern you desire and create a new part using that svg (you would need a separate part for each pattern you need.)
