Anyone has this connector as part ?
Thanks
Doesn’t look like it. I see 5,6 and 7 pin DINs but no 8 pin. If you have a data sheet for the part I’ll have a look at modifying one of the existing ones, but I’d need mechanical data for the part.
Hi Peter,
thanks for the availability. I Attached the datasheet. There are written measures. Rename it in “.pdf” format.MAB_8_SH_schwarz_black.pdf.fzz (172.8 KB)
Thank you
This should do what you want. As always before ordering boards print the pcb footprint out at 1:1 scale and compare it to a real part to make sure the footprint is correct. The hole sizes can be found in the drill.txt file:
M48
INCH
T1C0.094488
T2C0.051181
T100C0.052000
the first two are the non plated through mounting holes the bottom one at 0.052in (which seems a little big to me, but is what the data sheet specified) are the connector pins.
DIN8.fzpz (10.2 KB)
Ok Peter,
thanks very very much.
