OK here is a corrected part. The original (mostly because it is old) was apparently produced with Inkscape at 90dpi. The current 96dpi version makes the scale incorrect. I ran the eagle brd file through eagle2fritzing to get correctly scaled svgs and then did copy/paste from the original svgs to make this part which meets parts standards and is correctly scaled in all three views. I though about adding the USB connections, but I don’t think they are useful. I did change the 3 power pins from male to female so they won’t short (by auto connecting as male pins do) on the breadboard. You need to run wires to the pin to use them in breadboard view.
Digispark.fzpz (9.2 KB)
