Hi i am trying to import a DHT11 sensor into my wire diagram. I have saved the image as .fzpz, but it won’t allow me to add my image? Is there a better way to go about adding images into your diagram?
While it isn’t clear to me what you are trying to do, a google search for “fritzing part dht11” (always the place to start when looking for a part) indicates one should be in core parts (but search doesn’t find it) and several projects that use this part. If you download the .fzz file for one of those projects you should find the dht11 part in the temp parts bin which you can then export as an fzpz file. An fzpz file is a complete part not just an image and that is likely why your image won’t load.
