Dfrobot pH probe
“Friends, I can’t find the pointed probe of DFrobot’s spear-tip soil pH measuring sensor on Fritzing. I urgently need this part for the drawing. Has it been published before? How can I find it?”
Link : https://www.dfrobot.com/product-1668.html
This is likely as close as there is.
DFRobot-PH-sensor.fzpz (34.5 KB)
“Thank you, Peter, but isn’t the sensor extension you shared designed for measuring water pH? Or are they similar structures?”
They are likely similar structures and that is as close as there currently is. It is possible (but not worthwhile) to make a custom part though. From a Fritzing standpoint they are identical (it doesn’t care about the probe.)
Thank you for your help.
