A google search of the form “fritzing part BMP280” will find fritzing parts. There may be a DFrobot part around.
edit
There isn’t a Sen0500 part around so here are two. If you want to use the board on 0.1 headers use the tht part, if you want to solder it to a board use the SMD part.
