DFR1075 esp32-c6 DFROBOT
DFR1075
Previous work, similar parts
i think not similar part
https://wiki.dfrobot.com/SKU_DFR1075_FireBeetle_2_Board_ESP32_C6
espresiff esp32-c6
These two parts should do what you want. One is tht (through hole) and the other is SMD (if you want to solder the unit to a PCB.) In both cases the mounting holes are not drilled by default, if you want the mounting holes you need to drag a hole from core parts/pcb/hole in to the sketch place it on top of the hole in silkscreen and change the size to be correct.
dfr1075-smd.fzpz (25.0 KB)
dfr1075-tht.fzpz (25.2 KB)
Hello Peter!
You saved the day for me!!! Truly appreciate it. The THT version is what I need, but perhaps when I get ambitious (for Assembly out-sourcing) the other one will come in handy too. Thanks a bunch.
I have to learn to search better; I did a cursory search using the keyword Firebeetle and could locate only another version (and a smaller board one too) which weren’t a perfect match for my needs. The files you have provided are exactly what I was seeking.
Regards.
In general the best way to search for parts is a google search of the form “frtizing part part_name” where part name is as exact as you can get to the part you want. This one I think is hidden in another post for a different part but since I made it I was able to find it. Searching in the forum search bar also works but won’t find parts on the web in general.
