Since no one with more knowledge is replying, I’ll have a bash (although I am not an expert on bins.) I suspect the core bins are locked out from modification likely because they are compiled in to the code. If that is the case (which I’m not sure of) it will take a code change to remove the bins. Hopefully someone has a better answer (or can confirm this one if it is correct!)
I was starting to suspect that these bins are ‘baked in’.
It is a shame that there are some critical issues, the answer to which seem so hidden or at least hard to find.
I did some digging on this issue. On my AppImage Fritzing, I can find the Fritzing.conf file.
It is in ~/.config/Fritzing.
In there is the Fritzing.conf file. The bins are referenced in a series of numbered lines.
So I deleted references to a particular bin in the config file. When I restart Fritzing, the bin remains and it has been added BACK to the config file.
I tried again, making the config read-only.
The bin STILL reappears!
I am assuming that the cionfig simpy allows a fast loading of bins, but that Fritzing anyway does a ‘bin scan’ somewhere.
I suspect that the ‘somewhere’ is in the appimage…
Honestly, what I am trying to do is not unreasonable. The standard Fritzing install comes with a bunch of bins that I will NEVER use - the program even gives a function to delete them. But it is greyed out…
I do appreciate the work that is going into the writing of this code, but honestly I am aready checking out KiCad tutorials because it seems that there are other Fritzing issues, the solving of which will necessitate many google-rabbit holes i.e. waster time… life is short!
Find the folder where the bins are stored (in my computer “C:\Program Files\Fritzing\fritzing-parts\bins\more”) and delete the ones that you do not want. This works in my computer, Fritzing 1.0.1 on Windows.
Fritzing simply doesn’t have write access to these most of the time, for example when they are in the AppImage. I recommend to not delete any files from the installation. If you already did, I’d recommend to download a fresh copy.
