need this library
Can someone share ?
I only have this file without PCB layout
2.1mm Barrel Jack with Terminal Block.fzpz (9.3 KB)
need this library
Can someone share ?
A google search of the form “fritzing part barrel jack module” which is the best way to find parts turns up this post which may do what you want (typically these won’t have pcb because it isn’t pcb mountable, I don’t know what the listed module does.)
