I need to have a 1.5mm hole in the PCB.
when I insert the hole I already find the values set: 1mm, 2mm, etc.
If I try to change from 1 mm to 1.5 mm it doesn’t get the decimal.
how do I solve it?
Thank you
how do I solve it?
Thank you
Drag the hole icon in to the sketch and position it, then change the hole diameter in Inspector like this:
There was a bug that was fixed in version 1.0.3. are you in a previous version?
The workaround is to change the language to English.
thanks it was the version to update,
now works.
