Hi all,
I am trying to create a library of parts for the Voltera V-One PCB printer.
Voltera sells standard size “blank” PCB’s on which you can print your circuits.
Ideally, in Fritzing, I would like to pull a blank Voltera PCB part from the library.
Then in PCB view, instead of the fritzing default PCB, it would show the dimensions, outline, silkscreen (pre-installed via’s) etc. from this custom part. It would also be nice if it was already sticky by default.
Creating the part or SVG is not the problem, but is there a way that dragging a custom part into the project somehow replaces the default PCB?
I know there are workarounds, like setting a custom image for the PCB, but that would require extra actions.
Thanks in advance!
