Hi, I’m new to Fritzing. Many years ago I dabbled in electronics working from doodles that were drawn on copper with a pen! I think the Fritzing application is brilliant but I wonder if there is a way to draw a copper track that would accept connections in the future. For example I’d like to run Vcc and GND tracks around the board perimeter in advance of connecting parts.
Thanks a lot! Pretty obvious when you see it. I was too focussed on looking for functionality that wasn’t there!
If you do not want the doubled pin connectors, I think you could also place a pad with a size set the the same as the copper trace width. That should provide a place to connect to, without needed a real end connector.
Thanks! I did actually end up using pads and discovered that I could get rid of them after by first removing the segments of track attached to them.
Also I was able to create connection points on the track by adding bend points so that I could then draw a wire from a component to the bend point. At least it looked like it worked!
