CR1220 battery holder PCB part
I’m trying to put a PCB together which includes a CR1220 battery holder. I can find one for CR2032, but not CR1220. Given its quite a common battery type, I was just wondering whether anyone was aware of a current part for this?
This is an example of what I had in mind.
Many thanks,
While it is likely that a part could be made from this data sheet , it lacks information such as which SMD pin is plus and which is minus or if the holes rather than the apparant SMD pads are intended as the connection points. From the picture I would assume that the connectors are the SMD pads but no indication of plus or minus on either.
edit forgot to add picture
