Texas Instruments IWR6843 mmWave Radar Sensor Evaluation Module (IWR6843ISK / IWR6843LEVM)
Your previous work, similar parts I have searched the Fritzing Core library, the official fritzing.org downloads, and github repositories, but no working part (.fzpz) or equivalent footprint exists for this specific 60GHz mmWave radar module.
(Please drag and drop your clear top-down image of your specific IWR6843 board right here before posting)
Official TI Product Page and Technical Documentation: IWR6843 data sheet, product information and support | TI.com Official Datasheet PDF:
Footprint Breakout board / Evaluation Module (Uses standard 0.1" pin headers for power/UART and a high-speed 60-pin Samtec connector for raw ADC data).
Type I did not read this Breakout board, sub assembly, plug in module (A) Antenna (AE) Battery (BT) Capacitor (C) Diode (D) Display (DS) Fuse (F) Hardware , mounting screws, etc. (H) Jack, fixed part of a connector pair, header (J) Relay (K) Inductor, Coil, Ferrite bead (L) Loudspeaker, Buzzer (LS) Motor (M) Microphone (MK) Plug, moveable part of a connector pair (P) Transistor (Q) Resistor (R) Thermistor (RT) Varistor (RV) Switch (S) Transformer (T) Integrated Circuit (IC) Crystal, Oscillator (Y) Zender diode (Z) Other (please specifiy)
