Hello. I’m new to electronics but I want to make some awesome device with fritzing.
but, I’m not sure I configured circuit correctly or not now.
I’m confused with below circuit :
please see the part marked with green circle and red circle :
I want to insert red circled jumper(servo female jack) to green circled servo pin header for configuring.
If I don’t insert jumper to pin header it should give ‘0’ signal to pin
and If I insert jumper to pin header it should give ‘1’ signal to pin.
did I configured correctly, is there no possibility of short?
red lines go to common vcc rail and black lines go to common gnd rail of breadboard(powerd from swtiching regulator). no special things outside of the picture.
