Hi. I’m using version 1.0.0 and I’ve not used it for a while (several months). When I opened the program this morning, the My Parts bin is empty. Have you any idea what could have happened to it or how I can get it back, please?
Thanks,
Chris.
As much as can be said is something bad happened to your user directories
On Windows they are in
linux
~/Documents/Fritzing/parts
~/.config/Fritzing
Mac
~/.config/Fritzing
if you have backups, you could try restoring from them, otherwise you would need to reload the.fzpz files for the parts you had. If they get deleted Fritzing will create new empty ones which may be what happened here.
