trying to change component values like R and C. How do you do that? I am using 1.0.08 version
Select the component after it has been placed in the sketch (make it active). Change the value in the inspector window. That has a drop down with ‘typical’ values in it, but you can also type in other values if needed.
As an extra, if you need several parts (resistors for example) with the same value, place the first one in the sketch, set it’s value, then copy it instead of placing a new one from the parts bin. That way, the value that was set gets copied as well as the part.
Thanks for your excellent response. I’m an expert now!
