Capacitive moisture sensor relay
I wonder if you have a component similar to this moisture sensor:
Screenshot 2024-06-23 at 21-26-36 Capacitive Soil Moisture Sensor Module _ Soil Humidity Digital Display Relay Control Module Automatic Watering For Arduino - AliExpress
Depends if you want just the moisture sensor or that and the relay. This google search “fritzing part soil moisture sensor” finds the various moisture sensors that have been made, I doubt the relay module exists as a part (although it may.) There doesn’t appear to be enough information in the web page to make a part for the relay module, the connection information is lacking.
I see. Thank you. I appreciate your help.
