I’m running on a Mac, OS X 10.11 (El Capitan). I’ve built brd2svg successfully with a couple of changes to the .pro file and the qmake command get it to build. I’m running Eagle 7.6.0 in “freeware” mode. I seem to have two problems:
When I run brd2svg it starts OK and Eagle pops up in the background. It runs for a while but I get an error as shown below:
$ ./brd2svg -e /Applications/EAGLE-7.6.0/EAGLE.app/Contents/MacOS/EAGLE -w ~/Documents/Arduino/DollLights-BT/Fritzing/ -c contrib
looking for all.packages.txt in “/Volumes/DroboM1/Projects/Fritzing/eagle2fritzing/brd2svg/all.packages.txt”
“unable to finish adafruit tlc59711 v1.brd"
QProcess: Destroyed while process (”/Applications/EAGLE-7.6.0/EAGLE.app/Contents/MacOS/EAGLE") is still running.
parsing "adafruit tlc59711 v1.xml"
generating paramsgenerating bin
done
Perhaps if I solve that one I can get the resulting part to import into Fritzing but that’s the second problems.
It does look like all the part files are created though.
The docs state that the parts files should go into ~/.config/Fritzing but I also find config files in ~/Documents/Fritzing … I’m not sure which is the right place. In any case, putting the parts folder into either place has no effect.
Any idea what I am doing wrong?
Bill W
