added net label part to schematic sheet, can’t find any editable field for the net label text in the inspector window.
should be an editable field in the properties section in the inspector window.
v1.0.8 on windows 11
KjellM
2
Did you try clicking on the name to edit it?
The edit field is easy to overlook or mistake for static text.
More details are here:
Thanks, had same problem as SaintNeki, i missed the greyed out title field.
