I’m really new to this software and need an arduino mkr connector carriers (grove compatible) for a school project. I tried making it on my own using the eagle2fritzing method but couldn’t wrap my head around it as i have no experience with eagle nor fritzing.
Does someone think they can manage? it would mean a lot!
This part should do what you want. Note pcb consists of only the board outline and the mounting holes (in silkscreen, so they won’t be drilled unless you drag a hole over them in your sketch and set its size appropriately.)
arduino-MKR-connector-carrier.fzpz (41.3 KB)
This is perfect! Thank you for you time dear sir!
