hello ,vanepp
please , I want the parts in the pcb because i did not find it in the parts , which is (HE12P24LRN )
- I have project that i need quickly
hello ,vanepp
This should do what you want.
edit: replace with a correctly spaced part.
hiecube-he12p24lrn.fzpz (4.7 KB)
Vanepp
That’s not what I want is the same as everything but the distance between + and - is not the same scheme I sold them to you.
You are correct. I just replaced the part above with a corrected one. You will need to delete the original part and shut down and restart Fritzing in order to load the new one.
