Can someone Help me with a diagram
actually idek what i did , i tried recreating the problem after i reinstalled fritzing but i couldnt , it was most confusing
That isn’t uncommon. There are at least (and probably more) two possibilities: your Fritzing install was corrupted somehow (antivirus actions is a common cause of that, although I think the installer may help with that) or the more likely, some so far undiscovered set of actions in Fritzing triggers the bug (that was the case in the routing database corruption that took me 5 years of trying to recreate!) They can be almost impossible to find. I had around 10 examples of routing database corruption (including one that should have been easy to recreate) but couldn’t do it until it happened to me one day and I remembered enough of what I did to reproduce it (after which the bug got fixed!) For a new user it is almost impossible to remember what you tried to get where you are.
i dont thinkj it would be a problem caused by antivirus , it might just be cus of a bad installer , files sometimes get corrupt when installation is paused so that might’ve happened . I think my fault might have been that hile it looked like i was connecting the wires to the VRM i actually connected them to each other? that is my speculation
