Pololu 5V, 15A Step-Down Voltage Regulator D24V150F5
pololu_D24V150F5.fzpz (10.0 KB)
Note by default the mounting holes are not drilled in pcb. If you want mounting holes in the sketch you need to drag a pcb/hole set to the correct size over the hole in silkscreen.
can you provide male bug strip fzpz file
